Re: hydraulic psi guage-is oxygen guage ok?
Posted by bc on January 31, 2008 at 14:42:59 from (208.190.253.101):
In Reply to: hydraulic psi guage-is oxygen guage ok? posted by bc on January 31, 2008 at 12:34:44:
Thanks guys. Actually the farm supplies around here don't carry them. They had the oxygen ones. But they steered me to an industrial supply this afternoon that can order me one for about $20. They give me a choice of 0 to 1000, 3000, or 5000. I kinda thought the max these tractors would put out would be 3000 and the working psi is supposed to be 1600 making a 0 to 3000 guage a little more accurate. But I can order the 5000# guage if necessary. I just have to see where I can put it and what size fittings I would need. To trouble shoot the regular and power steering, I may need to use 2 different sizes. The lines going to the power steering cylinder are smaller.
Also no one with hyd. fittings carries any tees and bushings. Would you suggest brass, black pipe, or galv. pipe with that high of psi. If I can find the right place, I would leave the tee in permanently and maybe bullplug the guage hole.
