Re: cub oil pressure
Posted by Gene on January 31, 2008 at 17:37:49 from (64.85.222.12):
In Reply to: cub oil pressure posted by oldiron29 on January 31, 2008 at 14:53:34:
[quote:392671da83]How would you check the releaf valve?[/quote:392671da83]The problem will not be the pressure relief valve - it's located down stream from - on the pressure side of the oil pump.
If it's a mechanical problem - it' either in or at the oil pump or the oil pickup.
Suggest using a slightly heavier oil - and see what happens. I'm using 20W50
