Re: Farmall Hydraulics, Open or Closed Center System
Posted by Janicholson on January 31, 2008 at 18:52:53 from (66.173.50.92):
In Reply to: Re: Farmall Hydraulics, Open or Closed Center System posted by bc on January 31, 2008 at 18:18:19:
As simple as I can make it, and just barely satisfactory explanation.
Open center has a clear path from pump to valve to reservoir, back to pump. No restrictions until valves move fluid into attachments.
Closed center Has a valve which maintains a pilot pressure on the pump, and pressurizes the valving as needed on demand. The pump is always under pressure, but not dead headed.
A priority valve in an open center system is similar in that it supplies pressure to a system (like power steering) while the main flow goes to the open center valves. JimN
JimN
