Posted by YG00267 on January 31, 2008 at 18:56:10 from (74.170.246.204):
I recently purchased a 1952 Super A Farmall to restore. It runs great, but has oil leaks. I removed the hydraulic cylinder block that sits under the gas tank to replace some seals. When removing the block, a part fell out of a hole where the manifold block mounts to the cylinder block. It looks like a small CO2 cartridge and must control the hydraulic flow some way. I do believe it is a valve. I am not sure if there were other parts that fell out. (ie spring or something)nor do I know how it goes back together. Based on the witness marks on the valve, I put the cylinder block back together and the front lift will work. The back lift is not working. Can both lifts work at the same time like newer model tractors? Does anyone have an idea what might be wrong? There are only two holes and one is for the filter, so I know it is in the right place but might be missing a part or could it be backwards. Thanks for your time, Glenn
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
