Re: cub oil pressure
Posted by Janicholson on January 31, 2008 at 19:46:11 from (66.173.50.92):
In Reply to: cub oil pressure posted by oldiron29 on January 31, 2008 at 14:53:34:
The cub oil pump is built into the block. That reality limits many repairs (like replace the pump)
They do loose prime. Thicker oil will make it some better if driven often. I would fix it by using a small 3/4" plastic check valve on the oil pickup in the pan. This will take some modification of the existing pickup, but it will prevent drainback into the pan while assuring full delivery of oil. Making a new strainer for it, and making sure it has no leaks, and having the suction screen submerged will be mandatory. Good luck, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
