Low voltage to the starter and Ignition at starting is the mos likely issue. This assumes the mentioned parts are in adjustment, and the timing is on. The first tool in my box to be pulled out is a starter draw meter. It is cheap <$20 and so very easy to use. It is just placed against a battery cable and looked at while cranking. The tractor should be pulling about 275 to 350 amps while cranking. If there is more than this, it is probably a dragging starter motor, or other starter grief. (rebuilding the motor is easy) if it is less than that amount, the cables might be small in copper (not necessarily rubber)and/or the battery is low in CCA or weak from age. The cheap meter pays for itself instantly. Cables must be double0 (00Gauge) they must be copper with soldered on terminal ends. There are gell batteries (pricy but great) with high CCA (maybe 800 or more that fit the bat box) that will twist off a 10" hawthorne tree at the stump. Good luck. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
