Re: IH 300 always hard to start
Posted by El Toro on February 01, 2008 at 06:42:10 from (64.12.116.73):
In Reply to: IH 300 always hard to start posted by Danny the blacksmith on February 01, 2008 at 06:03:34:
I think Jim has pin pointed the problem. I would
replace all the battery cables with 00 cables. You need to have your battery load tested too. Replace it if has a weak cell. You probably aren't getting battery voltage to your ignition
coil. If your wire from the ignition switch to the coil is cracked replace it and from the coil to the distributor. If your starter is requiring
too much battery voltage there's probably not enough left for the ignition. Hal
