Re: IH 300 always hard to start
Posted by Brownie450 on February 01, 2008 at 08:39:12 from (216.51.158.220):
In Reply to: IH 300 always hard to start posted by Danny the blacksmith on February 01, 2008 at 06:03:34:
Has this 300 been overhauled? Have you done a compression check? Check the intake manifold gasket. Since it runs well after starting, the carb shouldn't be suspect. While it is running, pull the coil wire out of the distributor cap enough to make the spark jump a 3/16" gap. If it's not a hot blue spark, go looking into the distributor [points/ condenser] for any trouble there.
