Posted by ChrisAS on February 01, 2008 at 16:23:19 from (75.170.117.3):
In Reply to: 706 weak hyd in fel posted by russ in canada on February 01, 2008 at 15:22:40:
You can't test that way because the pressure will only be as much as it takes to lift the load. Just unhock loader an put guage in the coupling where the loader is and pull hyd lever then the pressure relief valve will open at the max pressure that it will hold. The way you are testing the relief valve may not be opening.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
