Re: F12/F14 Universal Joint Bolts
Posted by Dave Allgire on February 02, 2008 at 07:20:49 from (24.217.155.142):
In Reply to: F12/F14 Universal Joint Bolts posted by Dave Allgire on February 01, 2008 at 14:56:37:
Thanks for all of the replys. I just bought 4 new bolts w/nuts off of Ebay. I'm replacing these bolts because they are worn about halfway through. I believe because of usage and age the rubber washers have shrunk allowing the flat connector plate to loosen and "chatter" on the bolts. I guess I'll see if I can get them built up and turned back to their correct diameter. Does anyone know if the bolts from an H will work?
