Re: electrolysis question
Posted by Haas on February 02, 2008 at 19:22:49 from (12.65.24.219):
In Reply to: Re: electrolysis question posted by Scott Rukke on February 01, 2008 at 18:26:20:
These were NOS parts that I was trying to clean up. I think if the paint was put on clean bare metal, that electrolysis would not take it off. On the other hand, if there is rust (iron oxide) under the paint, the paint might loosen and come off. I don't believe the electrolysis would have any direct affect on the paint. The other items I tried cultivator parts) were only rusty, they did not have any paint on them and the rust was removed reasonably well. I only had a small system in a 5 gallon plastic bucket and a 2 amp battery charger. I have no ideal how much amperage I was getting, but I expect it was more than 2 amps, as on the 12 volt setting, I was getting maybe 8 or 9 volts.
