It almost sounds like the carb might be out alittle along with other issues. You'll need to probiably rebuild the carb. Also, if it is that hard to start I would be suspect the electrical system needs some attention too. I almost wonder if you are not getting a real hot spark. A weak spark could be from a number of things. Two that come to mind which you haven't mentioned attending to are the ignition switch and the little insulator from the coil to the distributer that the points are attached to. It could be cracked and it's leaking and arching in there messing with your timing. Just by doing some simple tests with a multimeter will help a bunch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
