I have seen pistons that have gotten slamed by screws that were,not damaged but left an impresion of the screw and some that blew a hole in the top. I have seen valves get bent from closing part way on a screw and the piston tapping the valve and I have seen engines locked up from liquid in the cylinders. I have also seen an engine suck in a screw and it went all the way through and did nothing but hit the spark plug ground electrode and close the gap causing a dead cylinder and then blow out the exhaust never to be found! I would say first thing to do is get a compression tester and go through all cylinders and see what that says.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
