Re: Choke Plate Screw Vanished - Farmall H
Posted by Brownie450 on February 03, 2008 at 03:06:11 from (216.51.158.220):
In Reply to: Choke Plate Screw Vanished - Farmall H posted by Horse-George on February 02, 2008 at 21:39:57:
There is quite a bit of room between a top dead center piston & the head/valves on an H--- compared to the size of that choke plate screw. The screw probably would have been doing a dance number up in the combustion chamber for a while as opposed to killing the engine abruptly as you said. I believe I'd pull the head & see what's going on in the upper end just to ease your mind.
On the screw getting sucked up in the manifold--anything is possible--there is a pretty good air flow through a carb. Are you sure there wasn't a foreign object that may have gotten lodged in the transmission gears to kill the engine--& then fallen out? Our MTA had a gear chip get lodged once & it shut the engine down right now.
