Re: Help Identify Model - Farmall H Sickle Mower
Posted by TomH in PA on February 03, 2008 at 05:25:22 from (67.142.130.18):
In Reply to: Re: Help Identify Model - Farmall H Sickle Mower posted by Brownie450 on February 03, 2008 at 03:15:20:
If it attaches to the axle it was probably set up for a C rather than a SC. I had one for a 200 that attached to the fast hitch. Really just an extra fast hitch drawbar with the mower bolted on. Does yours look like a C drawbar with a mower bolted on? That's sort of what I have for an H now, but a previous owner "customized" it quite a bit and now it doesn't work right (mounts too close to the PTO so when it breaks away the shaft comes apart).
