Re: engine clutch not releasing
Posted by ihc49er#2 on February 03, 2008 at 13:14:50 from (216.123.197.144):
In Reply to: engine clutch not releasing posted by 560 wjr on February 03, 2008 at 12:32:22:
andy, a person usually shifts gears with the tractor running, dont you think.but anyway i know what he is talking about . my 560 was the same way.adjusted it all to spec.and no way you could get it out of gear if on slight up grade, all most like it had the brakes on a bit. i slit the tractor and replaced the clutch disc because it was at the rivets.it shifts very good now, like from 3rd to 4th with tractor rolling. no way before . idont have an actual explanation, other than maybe grease or oil on disc or slines and not releasing.my 460 is next , as it does exactly the same thing.its all set to spec. but will not shift properly.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
