Re: Need Resistor for 12v Conversion - Farmall H
Posted by Brownie450 on February 04, 2008 at 06:19:31 from (216.51.158.220):
In Reply to: Need Resistor for 12v Conversion - Farmall H posted by Horse-George on February 03, 2008 at 21:46:08:
I get my resistors from MCM Electronics at Centerville, OH. Use a 25 watt wirewound 10 ohm--10%. Stock #48-10. Comes 5 per bag for $4. Of course, shipping & handling are going to kill you. Looking on e-bay the other day--saw wirewounds 10 ohm/75 watt 10% for less than $1---.
I usually mount the resistor on the wiring harness or a convenient flat bracket near the alternator using a pair of plastic/ nylon cable ties. Back side of the alt is preferred mounting site to keep away from fan air movement. Use soldered connections for good/ dependable connections. Have done probably 20 to 30 of these conversions, & this seems to be the best route. Use strain relief when wiring to the resistor.
