George, the resistor you need is for the alternators excitation circuit and as Jim noted IS NOT the same as any ignition coil ballast...... From some GM literature I read once I highly recommend a current limiting safety resistor in the alternators excitation circuit versus no resistance at all and I use a 10 ohm..... While the power rating in watt isnt requited to be as big, if you buy like a 5 to 10 watt 10 ohm resistor they have bigger easier to wire leads n are more heavy n rugged then a smaller watts power rated unit.
The 10 ohms 5 or 10 watt resistior wires in series after the voltage source (ignition switch usually) and before the alternators lil No. 1 side excitation terminal.
An idiot light is probably even way more resistance then a 10 ohm current limiting safety resistor I use n the alternator still receives sufficient excitaion. I dont usually even use a diode since the 10 ohms usually prevents ignition run on which the diode can be used to prevent.
Ive seen em used with NO resistor or diode n they still worked fine but as a conservative I prefer at least somne degree of current limiting protection in the excitation circuit be it a 10 ohm or an idiot light or a diode which ahs a 0.6 voltage drop across it.
Get a 10 ohm 10 watt resistoir from Rat Shack is my advice.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
