Re: Original Gauges SMTA
Posted by Brownie450 on February 04, 2008 at 14:15:42 from (216.51.158.220):
In Reply to: Original Gauges SMTA posted by Larry NCKS on February 04, 2008 at 01:08:16:
A person just doesn't take note of what the gages actually look like. Ours came out with the standard cold-run-hot temp. gage. The oil pressure was red on the left side of travel [low] & I think the rest of the "sweep" was white with a white needle. Our oil gage went out & we put in a Stewart-Warner which hasn't caused any trouble.
The ammeter just had 0 in the center & D[discharge] to the left & C[charge] to the right with 5 marks equally spaced across the top --3 being over the C D & 0. Believe it said amperes on the bottom. Not sure--I'll check in the morning at chores & let you know.
