Re: Need Resistor for 12v Conversion - Farmall H
Posted by Bob on February 04, 2008 at 15:18:58 from (69.178.229.154):
In Reply to: Re: Need Resistor for 12v Conversion - Farmall H posted by mkirsch on February 04, 2008 at 14:33:44:
Several guys who hang around these boards have tried using an LED "idiot light", and it didn't pass enough current to excite the alternator at startup.
You are either LUCKY, or your alternator has a "self-exciting regulator" (one-wire alternator).
In cases where someone wants to use an LED "idiot light", they have used a 10 Ohm, 10 Watt resistor ACCROSS the LED pilot lamp unit to pass enough current to "excite" the alternator at startup.
Just posting this to help avoid someone being FRUSTRATED when their alternator won't excite!
