FUDGE! New 140 problem- Hyd unit bleed off
Posted by 1fortyfanatic on February 05, 2008 at 14:49:07 from (71.229.209.88):
To Hugh and Hal in part, and all members too.
Update. Put 4 bottles of alchohol in the tank, took off the sediment bowl and cleaned it out, took off the carb and cleaned it (including the screen tube on the fuel intake line) had to build a new gasket for the sediment bowl to stop the new leak, checked the rubber hose between the carb and the air intake for obstructions, and after all that.....no real difference. Still has no power under load and wants to drop the rpm down to almost nothing. Idles fine.
Marginally useable so I took it down for some fresh gas, and at the station, the rear blade dropped to the ground. Not in free fall, but really quick. Touch control lever backed down all by itself. After cycling it a couple of times, got the blade up enough to drive home (2 blocks) but had to hold the touch control lever up to keep the blade up. As soon as I parked it and let go of the lever, down went the blade with a clang. Went to pop the hyd fill hole bolt to check fluid level (it's never leaked) and got hot fluid trying to shoot out past the threads! Tightened it back up in a hurry and am letting it cool off.
My new theory? The hyd unit has been engaging trying to keep up this whole time and is robbing me of power. That perhaps the two problems are related. Any thoughts / advice? Thanks!
Signed: one really depressed 140 owner.
Dave
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
