Re: IH 786 transmission
Posted by todd hamilton on February 05, 2008 at 17:34:30 from (68.51.70.71):
In Reply to: Re: IH 786 transmission posted by PeterE on February 05, 2008 at 13:15:48:
Oh let's see how many of these transmissions I have shifted: 706, 886, 1066, 1206, 1466. I have many hours on all of these tractors. If the linkage is worn at all these transmissions have a habit of getting into two gears at the same time, at which time you will stop and manually unjam the linkage with a hammer and scredriver (tractor has to be shut off). These transmissions are not meant to be shifted on the fly since all of these models had a T/A. You can upshift in same range sometimes but down-shifting or changing ranges just won't work. I use 2nd gear a lot for pulling wagons and errands. L2 for control, H2 5 - 10 MPH is a good barnyard and across field speed, and reverse in 2nd is not too fast. That way I am only shifting one lever most of the time and then into H3 or H4 for moving down the road. For comparison L4 is the normal "field work" gear for pulling planters and tillage equipment. In the old days we use to plow in L3.
