Posted by Bob M on February 06, 2008 at 06:48:22 from (151.190.254.108):
In Reply to: Super-A ring gear posted by P and R Pete on February 06, 2008 at 06:24:31:
A couple comments:
1 - A propane torch may be sufficient to heat and remove the ring gear. (I've done it using a pair of propane torches working together).
Lay the flywheel on the floor supported by a couple bricks or similar. Then set your torch (or torches) as high as it will go and play the flame evenly around the ring gear. When heated to around 350 deg or so the gear should fall right off the flywheel - no pounding required.
2 - If you've gone to all the trouble to split the tractor and remove the ring gear why not replace the worn gear with a NEW one? (The new ring gear for my Super H cost $38 - I gotta think a new Super A gear will be comparable...)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
