Re: FARMALL M FLYWHEEL AND PRESSURE PLATE
Posted by Janicholson on February 06, 2008 at 16:32:05 from (66.173.50.113):
In Reply to: FARMALL M FLYWHEEL AND PRESSURE PLATE posted by LN on February 06, 2008 at 15:35:05:
Let the machinist know that the flange needs to be reduced in thickness to match the material removed from the friction surface. Let it also be known thatyou do not know if others did it correctly, and it needs to be at the correct depth. (it would be their task to spec it). Have them tell you the specification before they do any machine work. I would not face a clutch pressure plate. if enough is taken off to do good smoothing, it will reduce the net pressure. You do not want to remove material from the housing of the PP. Light hand sanding is cool using non directional strokes, and just a touch up of glaze. JimN
