Re: COLD 1486.....T/A
Posted by Janicholson on February 07, 2008 at 07:10:32 from (199.17.6.122):
In Reply to: COLD 1486.....T/A posted by nates90 on February 07, 2008 at 06:08:31:
If there has been a period of non use, there may be excessive moisture in the Hytran. This (and possible stirring of small flakes of junk) can cause the MCA valve to stick, or fail to operate correctly. The best thing for TA operation is use. I would never stop using a TA (either mechanical, or hydraulic) seasonally. I think it is an invitation to failure. Move the lever swiftly through its travel and do it. JimN
