Re: Fasthitch shims to use 200/SC implements with 350 tracto
Posted by ny bill on February 07, 2008 at 07:34:20 from (66.24.240.172):
In Reply to: Fasthitch shims to use 200/SC implements with 350 tractor posted by Bongo on February 07, 2008 at 05:36:17:
you can make your own like stated below. the factory spacers had a 1 1/2"? long x 3/16 or 1/4" roll pin crossways of the spacer, about 1/2" from the end. this roll pin hit the sides of the tractor socket and kept the spacer from sliding into the socket too far when you back up to the implement. in the day, we used the same shims for several implements, so didn't weld them fast. we had a super c with several implements that we used on a pair of 300s.
