Posted by davset on February 08, 2008 at 12:35:59 from (97.81.223.169):
In Reply to: B not cooling well posted by davset on February 07, 2008 at 13:32:28:
Thanks, guys. I talked it over with a couple guys at work today and pretty much the same thing. I got some radiator flush on teh way home this afternoon and put it in then cranked up and ran it for a while. I'll probably let it sit overnight then crank up again tomorrow, getting it warm enough to allow for some flow. The distributor is a very plasuible idea. At some point in the past a previous owner had "repaired" the broken governor spring by shortening it; there's no telling what else was done to get it to run "right." So far, it is OK other than a little sputtering a low idle. That tends to go away at higher speeds and under load. We'll keep at this thing and get 'er right. Thanks again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
