Re: Ring Pinion gear pattern (pic)
Posted by Janicholson on February 08, 2008 at 13:13:23 from (199.17.6.122):
In Reply to: Ring Pinion gear pattern (pic) posted by Doug C. on February 08, 2008 at 09:59:14:
I agree on the pattern, but believe that if there is movement with hand force on it there will be more with the engine twisting it A ball bearing in this location should have less than .003" axial play. If you can see it easily it is in need of replacement. JimN
