Re: 48 cub oil pan
Posted by old on February 08, 2008 at 13:39:09 from (4.244.222.245):
In Reply to: 48 cub oil pan posted by delawhere on February 08, 2008 at 13:34:02:
What I do is take a little silicone gasket sealer and sort of glue the gasket to the pan let it sit say 30 minutes to set well. What that does is holds the gasket in place so it will not slip or slide on the pan. Also to help keep the holes lined up drop the pan bolts in the gasket all around the pan when you put the gasket on the silicone that holds the gasket in place as the silicone dries. Doesn't take a lot just a nice thin layer all the way around
