Re: 48 cub oil pan
Posted by Andy Motteberg on February 08, 2008 at 17:05:20 from (4.143.223.12):
In Reply to: 48 cub oil pan posted by delawhere on February 08, 2008 at 13:34:02:
When I put a good oil pan on my Farmall H, I did not think it was that hard to get on with the gasket. I just put 2 of the bolts in and threaded them in by hand. It should not be difficult. Make sure the pan and engine surfaces are CLEAN, no dirt, grease, oil, old gasket remains, etc. Do not overtighten the pan bolts, too much tightness may split the gasket and you would need to change it again.Tighten the bolts gently untill all are snugged down and then tighten a little more so you can just see the gasket material BEGIN to squeeze out between the block and pan surfaces at each bolt location.
