Re: H transmission cover gasket
Posted by Dave S. on February 08, 2008 at 17:05:53 from (65.171.115.66):
In Reply to: H transmission cover gasket posted by neblinc on February 08, 2008 at 09:39:02:
Be careful letting to much squeeze out to the inside of the transmission. Pieces can come off and plug oil holes to the reverse idler gear and the bearing on the input shaft.
I have went back to using the gasket. If it has shrunk soaking it in water should work.
