You have to remove the final drive. You do not have to remove the axle from the final drive. Remove the rim from the hub and then the hub from the axle. Also I believe you will need to remove the fender. Also, brake connections have to be removed. Once all is clear, you can unbolt the final drive and it will slide right off, bringing the pinion shaft and the brake drum and band with it. I suggest doing one side at a time. Be very careful, as these offset tractors can be unstable when rear wheels are removed and are prone to fall off whatever supports you use. Make certain everything is well supported. Cub parts are not that heavy, but a shop crane or a helper would be of great benefit.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
