when you said the engine labored and ran hot before the distributor was reset, i'd take an educated guess and say the ignition timing was way retarded. this will cause a high cylinder temperature and a high exhaust temperature. i would take a good look at the valves, they prolly got overheated and its leaking oil down past the valve guides. may be just needs seals. it smokes now because the lower cylinder temp is not burning all the oil and you are getting smoke. run a compression test dry on all the cyinders, spark plugs out, throttle wide open. write the numbers down. squirt a couple pumps of oil from an oil can in each cylinder and retest. if the compression comes up 20-30 more pounds, your rings are worn, if not, its the valves.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
