Re: Help Identifying International Bulldozer
Posted by Kristof on February 10, 2008 at 01:54:11 from (81.244.196.250):
In Reply to: Help Identifying International Bulldozer posted by Freeride on February 10, 2008 at 00:17:31:
If it's anything like caterpillar, it should have a parkingbrake?
Did you remember to switch it off?
Did you check the axle connection between your Hydraulic Coupling and your transmission?
Is it a differential or brake steering?
If it is a differential steering, did you check if it works?
Before you trie, let her get warmed up a bit, than put her full throttle and put her forward and reverse a few time than neutral,than check if the differential steering works.
I believe your parking brake will be the problem.
Kind Regards,
