your post says you stumbled upon it in an abandoned shed. if it is not yours, dont fool around with it. in front of the bucket on the wall it says keep out private property. more than likeley the drive was disabled so someone did not joyride the dozer. if you want to purchase it, locate the owner. if it started and runs, its not abandonded. dont mess around with it.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
