Re: Bent push rods, bad gasket, and 8 hours later......
Posted by glennster on February 10, 2008 at 10:07:30 from (68.60.242.156):
In Reply to: Re: Bent push rods, bad gasket, and 8 hours later...... posted by 1fortyfanatic on February 10, 2008 at 09:47:54:
stop out at your nearest big box store or hardware store and get some plumbing solder and flux. its a lead free product nowadays, clean the area up good with sandpaper, 320 grit or get some plumbers sandpaper while you are at the store. apply flux to the area then solder. dot overheat the radiator, otherwise, other solder joints may fail.
