Re: Farmall A right brake question
Posted by RAY PELL on February 10, 2008 at 10:20:04 from (69.247.252.48):
In Reply to: Farmall A right brake question posted by RAY PELL on February 10, 2008 at 09:24:25:
At first I was just going to replace the brake
band as the one that was in it desolved into two
peices that resembled two small sheets of paper incased in an oil dirt cake. My goal is a decient
restoration of the entire tractor fixing whats broke and leaking, running it for a while then dissasemble and paint.So my intent is to replace all seals and bearings as i come across them.It's
a father son project he's 10 and were having alot of fun. So whats the drill on freeing up the diff shaft from the final drive? Thanks Ray
