Re: Rearend and Tranmission
Posted by georgeky on February 10, 2008 at 11:07:05 from (205.188.116.73):
In Reply to: Rearend and Tranmission posted by Andre Burnham on February 10, 2008 at 10:26:36:
They are suppose to be the same, but I ain't so sure. My C is slower in 1st and 2nd than my SC, but faster in 3rd and 4th. They will however bolt right up. Brakes can be changed, but will require as much work as just switching the gears out. The band type brakes of the C work just as well with a lot less maitainence. If it were me I would just make the swap, and leave the band brakes on there.
