If you have a pic of it, I appreciate it. I can't visualize the pivot bracket and framing. Thanks.
I've found using the bucket just leaves gouges and piles of gravel all over the place. Maybe there is a special technique to it but sometimes the ground isn't frozen under the snow. Some kind of blade you can skim the top of the gravel with seems like it would work best but I don't know.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
