Re: FARMALL H HYDRAULICS
Posted by gene bender on February 10, 2008 at 17:27:10 from (67.55.226.214):
In Reply to: FARMALL H HYDRAULICS posted by Steve Driscoll on February 10, 2008 at 14:50:19:
You didnt say what ite dia of the cycl is. Are you using a two-way valve. Easiest would be a larger dia cycl. Be careful about running a pump off the belt pulley just check the recomended rpm of the pump and psi and gpm. Have you thought about a tee in the line and a hy guage that would help.
