Re: Farmall B ignition timing verification
Posted by Bob on February 11, 2008 at 05:01:06 from (69.178.229.154):
In Reply to: Farmall B ignition timing verification posted by Steve_Md on February 11, 2008 at 04:39:51:
Is HAS to be @ TDC for cranking. When the engine gains speed, and the impulse kicks out, it jumps to full timing advance of about 30º ALL AT ONCE.
If you are REALLY seeing more than 30º to 35º advance, the impulse must have some worn parts.
