Re: 560 power steering
Posted by Hayshaker on February 11, 2008 at 06:17:26 from (199.151.125.249):
In Reply to: 560 power steering posted by 560 in KS on February 10, 2008 at 17:53:00:
One thing to check out also is to make sure your steering shaft knuckles aren't siezing up. I had checked, changed hydraulic fluid levels and the filter and it still wasn't working. I called my mechanic and was describing the problem. It would turn some easy then steer hard. He said take the shaft out and check the knuckles. Everything seem to move alright, but when I took the shaft off the lower knuckle would not swivel at all. Put a new knuckle in and it steered beautifully. I'm not saying that's your problem for sure but it is worth checking out. The knuckle was about $25.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
