Re: model M with no spark
Posted by old on February 11, 2008 at 08:51:15 from (4.245.6.229):
In Reply to: model M with no spark posted by doug gemmell on February 11, 2008 at 08:45:37:
One easy way to figure out where your problem is, is to hot wire it. Take a wire from the battery and hook it to the coil, ignition switch side. If you then have spark and it will run the problem is from the coil back to the battery. If it still will not run then your problem is in the distributor and you probably have bad points
