Re: Can't work on the ole tractor blues
Posted by GordoSD on February 11, 2008 at 09:41:02 from (66.115.200.140):
In Reply to: Can't work on the ole tractor blues posted by GeneMO on February 11, 2008 at 04:48:45:
If you need a bull pinion shaft bearing (ST102) I have a nice used one here for cheap.
Gordo
