Re: model M with no spark
Posted by El Toro on February 11, 2008 at 10:08:00 from (205.188.116.73):
In Reply to: model M with no spark posted by doug gemmell on February 11, 2008 at 08:45:37:
I would clean the points with some 320 wet or dry
and then see if it will start. If it still won't start and has no fire. You need to check for battery voltage at the coil with the points open. Should have voltage on both small terminals on the coil. No voltage here check the ignition switch. The feed wire to the switch
may be loose, broken or corroded and if there's voltage to the switch and none to the coil when in the on position. Replace the switch. Hal
