Re: 806 D sleve removal
Posted by El Toro on February 11, 2008 at 10:15:41 from (205.188.116.73):
In Reply to: 806 D sleve removal posted by 4440 puller on February 10, 2008 at 18:54:10:
third party image
You need a puller like NE Kirk's or like the one Keith made. You will need to have the puck undercut to fit the sleeve bore. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
