Posted by Andy Motteberg on February 11, 2008 at 10:52:57 from (4.143.217.129):
In Reply to: model M with no spark posted by doug gemmell on February 11, 2008 at 08:45:37:
First, check the breaker points, use some fine sandpaper and clean the contacts on the points. Check the points gap and make sure it is correct. Make sure the coil wires are good. If there is still no spark, check the condenser, replace it and see if you have spark. If not, the ignition coil may be bad. Replace it and see if there is spark. If you have a 12 volt system, make sure there is a resistor on the coil or it will burn out. Make sure your battery is charged up too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
