Re: MD still won't start
Posted by Haas on February 11, 2008 at 19:01:15 from (12.65.18.67):
In Reply to: MD still won't start posted by Peculiar Farmer on February 11, 2008 at 08:54:33:
You probably have the plug wires wrong, as Chuck said. Another possibility is that the magneto is 180 degrees out of time. The Mag rotates counter clockwise, opposite of what one normally thinks. The points cam only has two lobes with a 2:1 ratio gear in there to turn rotor at proper speed thus timing can be 180 out. If you are blowing oil back out the air cleaner when trying to start, one of these is likely your problem.
