Posted by teddy52food on February 12, 2008 at 06:38:12 from (209.237.111.169):
In Reply to: F-4 mag posted by 52G on February 11, 2008 at 18:58:30:
Is the governor working? Take off the cover next to the carb and watch & see if it opens the throttle when you put a load on it. Did you adjust the valves after you had it warmed up?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
