Posted by teddy52food on February 12, 2008 at 14:26:46 from (209.237.111.169):
In Reply to: Generator Trouble posted by Dean Meyers on February 12, 2008 at 12:16:02:
Sounds like the meter is wired backwards. If it is still 6 volts it should be positive ground. Is it? If it is negetive the meter will read backwards. Which way does the meter go with the lights on? (engine not running)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
